Does anyone know whether the wd tool wdidle3 works on an external drive? I know there is a green drive inside and I'd like to check the idle time (I presume it will be 8 seconds) and change it to 300 seconds.
I just thought I'd check before I open the enclosure to gain access to the drive inside...
Also, will formatting be quicker over sata than usb 3.0 or will there be no difference?
Apologies if the questions are dumb...
