I wanted to ask some things about case fans, it's my first time building a custom desktop and I figured this is the best website to ask.
1. Does the ASRock M3A UCC have enough power connectors for the 5 fans in the table below?
2. I'm using the Antec Three Hundred case, will dust guards on my intake fans be enough to protect against dust build up?
3. Can anything bad happen from negative pressure inside my case?
4. Since the Antec Three Hundred comes with a fan controller, can I control all of my fans with it, or just Antec branded ones?
5. If I can control them all, am I right in assuming that all fans have the same speed as read on the fan controller?
6. From my number crunching below, I can tell I really need the best case scenario, what is the best way to adjust my intake fans to a slower speed than my exhaust fans?
To put that last question another way, I'd like to know if I can control each fan individually. I wouldn't mind if the front two fans are controlled as a pair however.
I also forgot to add default values for CFM, in addition to the best and worst case scenario. The combination of lowest intake and lowest exhaust makes for -14.1 CFM (quietest). Highest intake and highest exhaust makes for -38.9 CFM (loudest).
Fan 1
Fan 2
Fan 3
Fan 4
Sorry for the wall of text, but I really want to get this right first time. This thread may even benefit future first time builders
Thanks for reading!
Fan 1
Fan 2
Fan 3
Fan 4
Thanks for reading!
