Question Dont know how to mount a fan in part of chassi
jay32267
Illustrious
So you want to mount it there but there are no holes in the case that correspond to the fan?
I've used zip ties (cable ties) and/or velcro to secure fans at times.
Ideally you could drill holes in the case...but there is risk in doing that ( I wouldn't want you to get metal chips in your electronics)...so I recommend zip ties or velcro.
Apr 15, 2020
Its fine. I found out how to do it but thanks anyway!
