I'd like to warn everybody not to use AMD's motherboard compatibility guide. This guide is replete with errors and when AMD makes mistakes there is no recourse. Recently I spent nearly $100 on an AMD processor after using AMD's own compatibility guide:
http://www2.amd.com/us-en/recmobo/DetailHandler/1,,30_182_869_4348^7923,00.html?queryID=2135
Mirror: http://linuxsavvy.com/staff/jgotts/amd-1.jpg
Some time between when I ordered my processor and when I installed it AMD realized their mistake:
http://www2.amd.com/us-en/recmobo/DetailHandler/1,,30_182_869_4348^7923,00.html?queryID=69047
Mirror: http://linuxsavvy.com/staff/jgotts/amd-2.jpg
My motherboard is an exact match for guide number one, revision 1.04 with BIOS 1014, so I spent about $90 on an AMD 3000+. After trying for several days to get it to work, including upgrading to a 500 W power supply from a possibly marginal supply, I thought something was going on. Lo and behold, that processor is no longer listed as compatible. I contacted AMD about their error and they said that they have absolutely no liability. So I'm out $90 and I may not be able to return my power supply either.
Buyer beware! Don't use this guide or you may be stuck with a processor you can't use and potentially be out hundreds of dollars. Hopefully AMD's refusal to own up to their mistake will wind up costing them thousands of dollars. From now on, I encourage you to think twice about purchasing products from this company.
