[SOLVED] Door speakers + subwoofers cut out when volume is too high
Jan 7, 2019
When the volume is turned up too high on my deck all of the audio cuts out in all of the door and subwoofer speakers of my whip. Please help.
kanewolf
Your amp is probably going into overload protection. Are the sub(s) and door speakers wired to different amps or to a single amp? Are the sub and door speaker wired together off a single channel of an amp?
divinitydrive
BANNED
Jan 16, 2019
Never encountered this problem before... Strange. How 'high' is the volume? Maybe the problem with amount of voltage? Check out this article https://liamscar.com/best-car-speakers-for-bass/ . It speculates on principles and standards you need to take into account. Or maybe just in case you will need new speakers.
phaelax
349
64
He's either putting out too much power for the speakers to handle (in which case will eventually blow them) or it's not getting enough juice to pump out the louder volume.
Or his stereo is just broken garbage.
