Dota2 crash/bluescreen PROBLEM
Anjo Suplente
6
I think the reason why my Dota2 is always crashing is that theres a bottleneck on my system. I dont remember but i think it started happening since the Big Patch update that Dota2 had then everytime i play it always crash to desktop or sometimes bluescreen of death.
this is my unit:
Mother Board: ASUS P8Z77-VLE PLUS
PSU: EPSILON 80PLUS 600 Watts
Processor: Intel Core i5-3550 CPU@3.30GHz
RAM: Kingston 4GB DDR3 1333 / PC3-10600 (1 x 4GB)
Hard Drive: Seagate Barracuda 500GB SATA
OS: Windows 7 Ultimate 32bit
Videocard: EVGA GTX 650 Ti SSC
CAN anyone help me fix this Problem?
Bottlenecks dont cause game or system crashes, and that 650Ti is nowhere near causing a bottleneck on your i5-3550. Have you overclocked your GPU at all? You may also want to download the latest graphics driver from Nvidia and see if that fixes the problem.
Hmm, if I am not mistaken that is an error you get when you are not supplying enough voltage to the processor. Have you overclocked your processor at all? It could possibly also be the GPU, is that overclocked? It could really be either one because when you start running DOTA2 both your processor and your GPU are drawing more power.
Best way to test this is to uninstall your Nvidia drivers and remove your graphics card, and try running the game with the integrated graphics. Obviously you dont want to play it on the integrated, but if the game loads up just fine with no problem then the issue is with your graphics card. Test it out and let me know.
I havent tried to overclocked my processor and my gpu.
Ive tried playing with a lower type of videocard and i finished a game without any problem but i have to lower my videosettings to inorder to play
