> Common sense tells me a room will heat up more using a 300
>watt heater over a speaker drawing a constant 300 watts.
Well.. then your sense isn't so common
> I'd just like somone to explain how 300 watts going in
>always produces the same heat output
since it can't be different, obviously it will be the same ?
>ake a 300watt air conditioner sure it creates some heat in
>the process but not the heat a 300watt heater would.
Indeed.. closer to the heat a 1000W heater would generate. You can't "delete" heat (energy), you can only move it. Moving it takes a considerable ammount of energy which is (you guessed it) wasted by producing even more heat (but elsewhere).
= The views stated herein are my personal views, and not necessarily the views of my wife. =
