Double click speed is messed up, I think my mouse is broken
CrazyDud24
4
The last few months I've noticed that sometimes my mouse double clicks when I did not. I have a razor laptop and my mom bought the death adder to go with it, however I do travel a lot so I think it may have gotten slightly damaged in one of the many times I've taken my laptop with me.
I believe either something in the mouse or the cord doesn't have a solid connection anymore so it breaks slightly and sends a double signal when I click once. that may make no sense at all, I'm not familiar with the inner workings with mice and even then I'm new to hardware.
I know its possible to set a longer maximum speed for double clicks but can you set a longer minimum speed so that it will ignore the second signal? I know its possible to disable double clicks but I don't want to do that.
I have a naga and I occasionally experience this problem myself, it all comes down to how you click on it. Find the exact spot and way of clicking that causes this and practice to avoid it. Otherwise, it's time to get a new mouse.
Alternatively, while you wait to get a new mouse you can check this out. It should help you to remedy the double click issue by forcing a minimum wait between double clicks.
https://superuser.com/questions/207731/configure-debounce-time-in-windows-for-mouse
