Question Double monitor problem
Feb 11, 2020
4
Hello there
I am using two monitors, one is plugged in to the video card, and the other is to the integrated. In the BIOS setup i enabled the integrated gpu. But when i turn off the pc it forgots it. Is there an option to remember it?
Spaceghaze
212
21
4,615
Are you choosing save and exit upon exiting the bios?
Sounds also a bit like the bios is reset for every time you turn of your PC. That might be because you need to change the CMOS battery.
Is it a stationary or a laptop?
Feb 11, 2020
4
Is it reseting everytime but it is not a laptop . Is there an option for it to not reset?
Spaceghaze
212
21
4,615
Actually as @Newtonius mentioned, even if you turn on iGPU in bios, having a dedicated GPU will usually disable it, but there should be a separate option to turn on for multi monitor support trough iGPU and dGPU. What is the model of your motherboard?
Feb 11, 2020
4
I have a DELL 0D28YY motherboard
Spaceghaze
212
21
4,615
Ow, i will need to do some searching to see if i can find bios settings for this motherboard. Unfortunately i am not able to do some at the moment. Hopefully someone that knows this PC/motherboard can chip in the mean time.
