Hi,
I have a unique need as a production company where I would like to put together a portable security camera kit. I would take these to different venues where they will provide me with an internet thru their router so it will be double NAT. The issue is getting it thru their firewall? Most of the time it is in convention centers or hotels where I have no control over their router/firewall
The kit would contain 1 Router, 1 AP, POE Switch, and 2 or 3 wired IP cams + 1 or 2 IP wireless cams.
What would be the best way to set these up to pretty much no matter where I plug them in, they will be able to remote in to my Dahua NVR or Blue Iris (camera software) server back at home? I use an edge router and already have a few locations using site to site VPN for cameras and works fine. I would like to stick with my edge router there.
Options I've thought:
1- VPN on router I plug into the venues internet line (probably will run into a double NAT firewall issue here)
2- DDNS on the cameras individual settings (Again think I will hit firewall issue here)
3- Using something like a PC with dual LANs to create some other kind of VPN that doesn't depend on ports?
4-Using something like himachi or NGROK on PC with dual LAN for connection sharing (issue here is trying to route all traffic thru Himachi when doing connection sharing, and will I be able to see the proper IP of each camera from the server end?)
I don't want to blow the bank, but buying proper hardware and spending money is not a problem. The more critical factor would be keeping it simple and in a small footprint.
I'm sure there has got to be a way, just like Ring is able to connect to any network and communicate without any opened ports...
I technically don't need two way communication, just making sure the NVR on the other end can capture video and ideally audio too.
Any thoughts?
Any thoughts?
