Hello,
My only goal is to put together a build that can handle 2x NVIDIA Quadro K5000, both 4GB 256bit.
Potential Mobo: ASRock Z77
RAM: Some forum threads say RAM is not relevant to GPUs but then Game-Debate's hardware comparison indicates that 1 K5000 should have 8GB of RAM. Should I get 16GB then? Or is that not how it works haha.
CPU: Game-Debate also recommends using i5 but since there are two, do I need an i7? Or two CPUS?
Cooling: Do you think just normal fan cooling would be fine to prevent this from melting down? It will be used to hook up 4 projectors (thats why 2 graphics cards) for edge blending software that requires NVIDIA Mosaic.
Honestly the only thing it will be running is picture slides and short videos, but I'm afraid of screwing it up somewhere and having parts not work. The computer itself will move around between tradeshows with ambient room temperatures of approx 80 degrees.
Thank you for reading I really appreciate it.
I really appreciate you taking a look. Thank you.
