Double shift keys
NOTE: If you need to type in a password to even get into Windows to do the following, make sure you attached an external keyboard first, to get past the password. Then disconnect the external keyboard and try the following...
1. Uninstall the keyboard driver.
2. Reboot the computer (without reinstalling the driver).
3. When it restarts, it should reinstall the driver on its own.
If this doesn't work, you may wish to try connecting/reconnecting an external keyboard and see if it works fine. If it does, then it could be the keys themselves that are the issue.
Also, if your device uses one, you may want to try updating the Synaptics Driver if the above doesn't help.
THANKS FOR THE REPLY the uninstall driver way didn't work, i find someone with the same problem as mine, and was able to solve it by updating his keyboard driver, Although im having a hard time finding a keyboard driver for my acer e1-572(pls help as well) i'll also try connecting external keyboard again tnx for the reply it really helps :) :) :)
