Double VESA Wall Mount?
sg4rb0
214
Hi I am getting more monitors. To start with, I'm having two monitors. They use 100x100 VESA mounts. I would like to keep my desk space clear, so I am wondering if there is such thing as a 2monitor VESA 100x100 wall mount anywhere? The closest thing I've found is just a dual desk mount.
if you want long twisting arm management, you might be out of luck and forced to use two separate arms.
short google for "dual wall mount vesa 100x100" gives following:
http://www.amazon.com/Tyke-Supply-Dual-Wall-Mount/dp/B0042P46OA
same search also gives page on ebay with different looks:
http://www.ebay.com/bhp/dual-monitor-wall-mount
http://www.ebay.com/itm/MonMount-Dual-LCD-Screen-Monitor-Wall-Mount-Arm-Bracket-/281071618105
http://www.ebay.com/itm/Dual-LCD-Monitor-Wall-Mount-Stand-Black-Deluxe-Gas-Spring-2-Screens-up-to-24-/361401120006
