[SOLVED] Download speed has TANKED please help
CrispyPotato
21
My download speed is usually around 15-30MB/s while downloading updates for games like RB6 or CoD but is at 1-2MB/s at the moment. I did an Ookla and a google test. I got it 1.46 download and .20 upload for the google. Then on ookla I got 4.8 download and 0.13 upload.... what happened to my internet? Why is it all of a sudden terrible? I can’t even download small updates to play games with my friends let alone play online if I’m lucky.
On my desktop(hardwired) I am getting these low numbers. But on my lab top(wireless)I am getting 325MB/a download and 11.23 upload off both ookla and google. What is wrong with my computer?
I used two different laptops, one right next to my router and got the 350mb/s then went on the furthest side of the house and got 40mb/s. when you say something on my computer do you believe it’s a virus? I don’t do much on the computer besides play games :/
Gotcha, so definitely not an isp issue.
To confirm there is nothing wrong with your computer, boot a linux live cd/usb and check speeds there. It should be full speed there, and if it isn't can possibly point to a hardware issue.
My download speed is usually around 15-30MB/s when updating games like RB6 or CoD but is at 1-2MB/s at the moment. I did an Ookla and a google test. I got it 1.46 download and .20 upload for the google. Then on ookla I got 4.8 download and 0.13 upload.... what happened to my internet? Why is it all of a sudden terrible? I can’t even download small updates to play games with my friends let alone play online if I’m lucky.
Quote Reply
malware scan?
it is downloading windows update?
I just downloaded the windows update today. i used malware bytes to scan my pc and it showed nothing as a “threat” to my pc. Is there anything else you recommend to locate whatever this issue maybe?
Use another device to test your speed. If it is the same, it could be a temporary isp issue.
If another device is faster, it's probably something on your computer as rgd1101 posted.
new system? or just the slow download happened recently?
full system spec?
The slow download happened recently. Within two days. The system is around a year or two old. The last thing I can remember downloading before the slowdown is the MSI Dragon Center to change the lighting on my GPU. Which I never got fully open. Besides yesterday the AMD software to monitor my CPU to see if anything was out of normal with it.
System specs:
CPU-AMD Ryzen 3700x
MOBO- Asus Tuff x570 plus
GPU- MSI RTX 2070 frozr
RAM- 16g DDR4 Corsair vengeance
PSU-700 bronze
