[SOLVED] Download speed problem
Jun 30, 2021
I have 10mbps internet and it downloading only with normal speed from google drive (1.3-1.4MBps) but from other sources like mega,mediafire,origin,steam it download only with 300-400KBps why? It used to be normal 1 year ago.
Remember that MB/s is Megabytes per second and mbps is Megabits per second. 8mbps equates to 1MB/s. So if your rated speed is 10mbps then you're looking at around 1.25MB/s download.
probably bandwidth issue on the server.
I saw on task manager that pc Using 9-10mbps when downloading from google drive, but when downloading from other sources it using only 2-3mbps. It's not only happening on pc but on every device, but maybe it is something with bandwidth.
True, also might depend on where you live, other factors like if your using wifi or not, if you are if there are many walls between you and the router, etc.
