Hey all, I have pretty inconsistent WiFi and occasional internet blackouts. I've spent quite a bit of time troubleshooting it, and I think I've narrowed it down to an issue with the power levels. See below for info. The downstream bonded channel power level is well above the 15 dBmV that is is considered the upper limit. Not sure about the upstream bonded channels.
I'm no networking guy, but assuming the above all makes sense, what is the solution to this? I think I may need an attenuator but am not sure. I should also add that I have an "Infinity Premise Amplifier, Model IPA1001. 52-1002MHz Forward Gain 15 dB. 5-42 MHZ Reverse Gain -1.2 dB"
Thanks in advance for your help!
Matt
edit: I can't seem to get the screenshot or tables to post. The downstream channels are all around 18 dBmV and the upstream channels are all around 42-44 dBmV.
Matt
