DPC_WATCHDOG_VIOLATION BSOD and NVIDIA driver issue
Tezzle
Hi there, I have a Windows 10 laptop with a GTX680M 4GB card, today while I was playing World of Warcraft the laptop blue screened with the DPC_WATCHDOG_VIOLATION and the dump file pointed to the nvlddmkm.sys, so I have the decided to update my NVIDIA drivers.
After the update my NVIDIA card doesn't work at all and the device manager shows the message "Windows has stopped this device because it has reported problems. (Code 43)"
I've tried using DDU to uninstall the driver and then install the old driver back but that didn't help..I'm still getting the "Windows has stopped this device because it has reported problems. (Code 43)"
Is there anything else I can try or did my graphics card just die?
There is some advice about that on here: https://forums.geforce.com/default/topic/861231/geforce-drivers/nvidia-amp-windows-10-how-i-solved-the-code-43-error-/
what happens if you run ddu and let windows try to install drivers?
if it wasn't a laptop, i would suggest seeing if card worked in another PC.
