@gardenman
Date | Driver | Description |
Jan 07 1978 | bridge.sys | |
is going to be part of windows, the date is a give away
Curious it shows up as it is:
Bridge.sys or also referred to as MAC Bridge Driver, is a driver for Windows, specifically for MAC bridge ports that are installed with the tunneling software for sharing of internet connections, such as WiFi and 3G networks.
https://www.reviversoft.com/processes/bridge.sys
So maybe BSOD is tied into Tunnelbear? See if there is a newer version.
I would remove this
None of the above mentioned in error but all too old for win 10 and may have caused it.
Dump doesn't really point at one in particular
It must be a new BSOD code as I have only seen it twice in recent weeks. Its likely to be a driver causing it.
Do you need both EaseUS & Iobit looking after hdd?
