[SOLVED] DRAM AND VGA LED
Oct 12, 2020
40
So i upgraded my rig to r7 5800x and asus tuf x570 plus and 3200hz 2 ram sticks 16gb total
installed and plugged everything but when try to boot up it shows a yellow DRAM LED and nothing is showing on the screen and the pc keeps runing
The motherboard probably needs a BIOS update to use that processor.
Or bent CPU pins.
Same motherboard. Yellow DRAM light means you haven't seated the ram properly. I've had the exact same problems. Since the slot only clicks on one side it is easy to not even realise that the other side isn't clipped in. It sometimes works but the slightest of knocks can make your pc turn off and have this exact status light problem you are experiencing.
If your RAM is seated properly, test one stick at a time to make sure one of them isn't dead.
