DRAM Frequency problem
timmenn
27
so put on the XMP function in my bios to get my ram up to 2400MHz like the instructions sad. But when i check the DRAM in windows with CPU-Z it says the DRAM frequency is 1200MHz
here are some pics from CPU-Z and BIOS : https://imgur.com/a/XY7bzRp
Oh man totally missed that one, you were already running 1200x2=2400, my bad thought I've seen 1066 as the main, you are all set then.
i took pictures from the bios : https://imgur.com/a/XY7bzRp
im pretty sure i saved and exit
- Thanks for the quick and pictured feedback, what is the 100.000? if it has an auto setting switch it to it ans see how it goes.
- Ram voltage on auto too
- Known issue discrepancy between CPUz and Bios especially when 4 modules of ram are installed
- Known issue memory controller down clocking memory in some circumstances especially when 4 modules are installed
_ sometimes manually setting DDR speed (double checking voltage and timings accordingly) instead of using the XMP overclock settings works better.
oke i whent back to the bios its the BLCK ratio there is no auto mode for it but 100 is the default
also i found a post on this forum where they say i have to doubble the frequency that is showing in cpu z to get mine and if i doubble that i get the 2400MHz
thanks for the fast help
