Dram LED is red, Computer won't boot
KanyeJ19
55
The DRAM_LED when my computer is turned on remains as a solid red. I've tried switching the RAM between the four slots and still nothing.
Any help with this is appreciated.
Specs: (If needed)
CPU: Intel i5 3470
Motherboard: Asus P8H67-M
RAM: Kingston 8GB (1stick of 8GB)
Graphics: HD 7850
Same here DRAM_LED was on the whole time. I tried pressing the MEM_OK button and holding it, nothing seems to work. Pc wont boot up not even the bios, then i got my 2x 4GB corsair RAM out of the slots and stick one of them back in, and the pc booted up normally, I switched off the pc again and put the other ram stick in..... that was it for me, now everytrhing works fine.
The CPU and the aftermarket cooler I have for it have been on for ages and aren't tight. I know that. What do you mean by "try a test power supply".
Considering it is the only desktop on the house, I can't test it with another one. And if it is a problem with the power supply, and not the RAM messing up. I'd need to buy an entirely new PSU wouldn't I?
I don't know if I have the latest BIOS, and the 8GB stick I have is a normal one, no fury. How would one go about updating the BIOS even though ones desktop won't POST/boot to display on a monitor?
Pressing and holding MemOK! was one of the first things I did. It'll just reboot my computer but it'll still flash red. That happened for about 10 minutes straight.
