S Sauronmordor756 Commendable May 22, 2016 18 0 1,510 Aug 29, 2016 #1 After installing my Asus 7170-A I noticed that there is a solid red light coming from the DRAM section. I pressed the MemOk button, it still didnt work. I also tried removing my RAM, and it didn't work after that. Please help.
alexoiu Titan Nov 1, 2012 39,818 250 126,990 Aug 29, 2016 #2 Try installing single RAM module. Test each slot/ See if still red DRAM LED. What CPU using? Upvote 0 Downvote
S Sauronmordor756 Commendable May 22, 2016 18 0 1,510 Aug 29, 2016 #3 alexoiu : Try installing single RAM module. Test each slot/ See if still red DRAM LED. What CPU using? i5 6600k Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,818 250 126,990 Aug 29, 2016 Solution #4 Then try with single RAM module and see if still red LED in all cases. Upvote 0 Downvote Solution
