Hi!
I had an MSI b450-a pro, 8gb ram hyperx fury 3200 (2x4), Zotac gtx 2060 and Seasonic Focus 80 Plus gold 550W. The PC was smooth and fast, i was very happy. I had 1 ssd and 2 Hdd also.
I had an issue installing new Leds, cheaps ones, and i tried to fix it with the pc power on: the system rebooted 3 times, and the all turned on but keyboard, mouse and nothing on monitor, not Bios. A big mistake.
And Dram led light on. Tried to change Ram Sticks in every slot and combination (with my Pc off, of course, after every test). Nothing worked. No Bios, all old lights and fans running, but nothing else. A Dead PC.
I had a guarantee so i changed the Mobo and bought new ram and a M.2 nvme 500gb Crucial:
Asus b450-f
Corsair Vengeance 3200 2x8 gb.
As far as i know, this ram is compatible with Mobo, like the hyperx fury i still have.
Mounted all with the new mobo and ram (same PSU, same GPU)... Does not detected broken or damaged pins in the CPU, as far as i saw while removing the old thermal paste...
and AGAIN Dram led is on, no monitor signal, and mouse and keyboard has no power. No Bios, nothing.
I changed the RTX 2060 for my old gtx 1050, wich i use in another old PC, and same issue. Tried to change the new Ram into slots, only 1, 2,etc... and even the hyperx... my first combination was the manual recommendation for Dual Channel. Nothing.
So... is it the CPU or the PSU? Or i’m missing something?
Do i need to buy new one CPU and PSU? I‘m very desperated with this ‘cause i don’t understand what’s happening...
Thank you very much.
Asus b450-f
