Question Dram not detected or fail
Jun 5, 2024
Recently i did my 1st build
I5 12600kf
Rtx4060 msi
Msi 760 tomahawk wifi ddr5
Crucial ddr5 16x2
And it doesn't boot debug light is orange color which the manual said dram not detected or failed
I tried every dimm slot 13, 24 and tried to boot by only 1,2,3,4 with 1 ram
You should populate slots A2 and B2 with a dual channel ram kit. If one, you populate slot A2, per the motherboard manual. How are you cooing that unlocked processor? Relieve some mounting pressure off the CPU's socket and see if that helps with the POST process.
You forgot to also mention the make and model of your PSU. You should breadboard your parts before you build them in a case.
