[SOLVED] Draw distance, Textures PROBLEM
Dec 8, 2018
5
Hi, I have played two games on my new PC that I bought. There is a problem that theres some kind of glitch ? I dont know ? OK, Assassins creed Brotherhood, highest details possible, 60 FPS easy, but objects in game, trees, grass, all those things disappear when Im more than cca 10 meters far.
Like if draw distance was set very low, but there is no draw distance and settings are MAX ! People like to disappear also, textures like to do weird things. IDK how to describe the broblem, so I will link recorded gameplay. Here: https://www.youtube.com/watch?v=ixmB5bYMaoM&t=10s
PC:
GPU: AMD Radeon R9 270x (2GB)
CPU: Intel Core i5 4460 (3.4 GHz)
RAM: 8GB
OS: Windows 10 (64 bit)
I have the same problem in AC1
HELP PLEASE !!! It is quite unplayable when everything is popping, people disappearing and trees appearing like 10 meters before me.
You do realise that this is a forum and the members here choose to answer a question or not! If you don't get a reply straight away then learn to have some patience and wait! You might get an answer but then again you might not! That's how forums work. As to your question it's probably due to your 2gb GPU and expecting to play games on max settings, try turning the settings down a touch and see if that helps. And mind your manners, you'll get more help if you do!
