[SOLVED] Dreaded e7250 with 1080 touch with air bubbles. Fix?
leeleses
14
I believe this is a common issue with the e7250 laptop.
There are air bubbles showing on the edges of the screen.
Does anyone know if:
1) The existing screen can be repaired somehow? I saw something about some kind of sealant and windshield sealant to stop the leaks from coming back maybe?
2) Does anyone know if the digitizer is somehow bonded to the LCD, or if there's a way to replace just the bezel/digitizer, and maybe without even having to disassemble the base and take the lid assembly off the base? Some stuff I saw online makes it look like the bezel and the digitizer are all one piece and the LCD itself is not the problem?
Thank You,
Lee
1| The answer was mentioned here, in your thread.
2| From what I can tell, it's one piece. In any case, you might want to invest in the entire lid, as shown here, to save you the hassle of disassembling the entire bezel.
