G Guest Guest Jan 21, 2013 #1 I need a drive belt for a tascam 34B can anyone help. This is the drive belt from the main motor to pinch roller assl.,
soundguruman Splendid Mar 3, 2010 4,816 0 23,460 Jan 22, 2013 #2 http://www.ceitron.com/passive/belt.html you need to measure the height, width and length, then order according to size... (use calipers to measure it) the new belt will be 2 mm shorter than the old one...
