Drive D is the boot drive and drive C is the system drive. Both are active. Bo
gaf007
7
I have a Windows 7 machine with two internal physical drives. Some how I made drive D the boot drive and drive C the system drive. Both are active. Both are physical. I need to make the C: drive both system and Boot. How can I move boot from D to C?
you cannot change these drive letters.
you will need to format and reinstall (with the 2nd drive disconnected)
this is a common occurance when people have a USB internal card reader. if you dont disconnect it proir to install you will end up with a F: as your windows drive.
So, to make sure I understand correctly, the C drive contains Windows, but it boots from D?
If so, this is a simple fix. Grab your Windows DVD, and stick it in.
Shut down your computer, and then unplug the D drive.
Startup the computer and boot from the DVD. Run startup repair and it should automatically create the necessary files on C in order to boot from that drive.
After you've booted from C, shut down and plug D back in.
