I posted about this drive before and marked the topic as solved before I ran more tests. Anyways I kicked out the cable of my external USB hard disk and plugged it back in 5 seconds.
It now fails SMART and is in good/bad health depending on the program:
Seagate told me to run seatools. The drive failed the short DST and long generic test (which happens in case of bad sectors according to the manual).
How can I see HOW MANY bad sectors there are? As I understand, the firmware will mark bad sectors as bad and not use them and I hope nothing mechanical was damaged except the sectors and no more damage will happen if I keep using the drive. Also it's not worth paying shipping costs (stil have 2 weeks warranty) if tests fail because there's just 1 bad sector.
So how can I see how many bad sectors there are? And would you think this is the best course of action, to occasionally check if the bad sectors increase?
