Driver Booster Or Driver Easy? Help?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hello, I've come to the forums seeking help. Just recently my dad and I have just completed upgrading our new system into a gaming computer. Now that we have the computer to successfully boot we need the correct and best drivers for gaming. I have used driver booster in my old laptop and it worked perfectly fine. However, my dad argues that driver easy is trusted will work better.
NOTE: We are trying to install new drivers! Not update old drivers because we don't have any drivers currently installed the computer. Also note that I'm asking which software is best, not if I should use them.
Which one will work better and give me the best performance?
Driver Booster: http://www.iobit.com/en/driver-booster.php
Or
Driver Easy: https://www.drivereasy.com/
Please, I need help! Installing drivers manually is a pain!
Usually, you don't need to update other drivers that often unless it's a new component.
Best thing to do is goto your motherboard / gpu or orther device webpage and download them from there.
drivereasy and iobit has mixed reputation
https://www.mywot.com/en/scorecard/drivereasy.com?utm_source=addon&utm_content=rw-viewsc
https://www.mywot.com/en/scorecard/iobit.com?utm_source=addon&utm_content=rw-viewsc
I personally would stay away from them. I also doubt they will find the missing driver for you.
Best thing to do is search your motherboard and missing driver on google
The best driver installer i yourself.
Most of these programs come with adware and sometimes install bad drivers that cause BSOD or device to stop working.
Most of software doesn't need updates anyway.
Usually you update the GPU driver and that's all.
Yes, I usually update my gpu driver only but, what about the other drivers? You didn't quite answer my question. Installing an updated version of my video card or any other driver is no big deal for me. However, finding the drivers is what I struggle on. I can't identify the driver on my computer because it is not installed. So, I'm asking which software is best, not if I should use them.
