Driver for linksys wireless adapter(WMP54G)
Did you try searching google? Your question is easily answered. You need to get the correct driver from ralink since Linksys doesn't make a Windows 7 driver
You may be able to use the Linksys Vista driver if you are using 32 bit. But if you are using 64bit you will need the driver from RALink.
Link
