Driver help for my monitor
suspenz
96
Ok well I just bought a new pc and for some reason it looks semi blury...but when i press on the auto button on the screen it adjust itself of course. Well first let me tell you the model of monitor i have Samsung SyncMaster 215TW
I thought if i installed the new driver from samsung it would resolve this problem...i installed it and nothing...I looked and it says for OS
215TW Driver (Driver) (ver.1.0)
Win 98/ME/2K/XP/X64....i do not see Vista 32bit...and yes that is what i have.
I dont know where else i can find a driver that supports my system...and if this is not the problem please let me know...the monitor was working fine with my other pc. It was XP Home 32bit
Thank you for you help
I would try updating your graphics card drivers. I assume you are using DVI-D.
I think the software drivers for the monitor is primarily used for the pivoting the monitor from landscape to portrait mode.
Maybe the DVI-D port of the GPU has issues. You could also try a different DVI-D cable if you have a spare.
hmmmm I did also update my driver for the video card and nothing. and for the DVI-D cable ill try and see if i have an extra cable laying around. is there anything else that could cause this?
the driver doesnt say if it support vista 32bit....do you think thats the problem (driver was for the monitor)
