Driver Issue Causing Bluescreens....
n00b82
179
Hello,
I keep getting a bluescreen on my computer, and it usually occurs in the middle of the night.
So i usually put my computer on sleep mode, and as of late it started waking up on its own, and my computer is pretty loud, so it wakes me up (making this an issue)
I usually would just shut it down, but it is kind of an inconvenience to wait for it to start up and start all of my programs in the morning, plus i have been getting bluescreens recently.
Here is the WhoCrashed:
On Tue 4/14/2015 2:49:48 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\041315-18423-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75BC0)
Bugcheck code: 0xA (0x0, 0x2, 0x1, 0xFFFFF8000408493C)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: scmndisp.sys (scmndisp+0x16D1)
file path: C:\Windows\system32\drivers\scmndisp.sys
product: SerComm® Neutral Wireless Solution
company: Windows (R) Win 7 DDK provider
description: SerComm NDIS User mode I/O Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: scmndisp.sys (SerComm NDIS User mode I/O Driver, Windows (R) Win 7 DDK provider).
Google query: Windows (R) Win 7 DDK provider IRQL_NOT_LESS_OR_EQUAL
Thank you in advance!
Drivers ? I can help
Go to iobit.com and Download Driver Booster 2.2 and Install it.Tap Scan and It will search for Missing,Corrupted and Outdated Drivers.For first Search,It will definitely find some Missing,Corrupted and Outdated Drivers.Tap Update All and It will automatically search and download the Latest Stable Version of the Drivers that are being Signed.It has major support to components and stuff.
It fixed my Audio Issue.Thanks
I wouldn't touch it with a barge pole.
It's driver issue, the driver running in kernel mode is causing trouble...
It seems your scmndisp.sys driver is causing trouble , which is part of Symantec software , WiFi dongles (NETGEAR?) or Antivirus
Do a windows update if you haven't done or update your corresponding driver.
You may want to be careful with driver software. Some of those apps have been know to download the wrong drivers and screw things up.
Yes, we have already found the problem, it's your wireless adapter from netgear. You should be very careful form driver installer software. Most of time they install useless adwares along with actual drivers. Don't be lazy to Google your adapter drivers. And if you cannot find them let us know.
+1
