Question " DRIVER-POWER-STATE-FAILURE " BSOD while using Orico HDD Dock ?
Mar 25, 2023
6
Hi Masters!
I have recently purchased an Orico 6228U3-C 2 Bay Offline Clone HDD Dock.
When it's connected to my PCs ( tried on two running Windows 10) I get " DRIVER-POWER-STATE-FAILURE " BSOD.
The drivers are installed but I don't know where it comes from!
I am using 2 x 4TB HDDs on it but most of the time only one is attached.
Please help is if you have an idea ; it's a pain in the ass that PC crashes in middle of the work.
🥂 Cheers 🥂
Hi Masters!
🥂 Cheers 🥂
Just to get it out of the mix.
Use device manager and expand the usb controllers.
Look at the power management for each section.
Do not allow the save power option.
Reactions: Gone9274
Mar 25, 2023
6
Yes shows as Disk Drives
Name: WDC WD40 PURX-64AKYYY0 SCSI DISCK SERVICE.
when I right click on it: properties:
General: This Device is working properly.
Policies: Quick Removal ✅
Better performance
Volumes : Empty data (blank)
Driver : All normal and up to date
Details: same as everything
Events:
Device SCSI\Disk&Ven_WDC_WD40&Prod_PURX-64AKYY0\6&37334810&0&000000 was configured.
Driver Name: disk.inf
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Driver Date: 06/21/2006
Driver Version: 10.0.19041.789
Driver Provider: Microsoft
Driver Section: disk_install.NT
Driver Rank: 0xFF0005
Matching Device Id: GenDisk
Outranked Drivers:
Device Updated: false
Parent Device: USB\VID_152D&PID_0565\MSFT30RANDOM__BF833EEF5DA5
Better performance
Events:
Outranked Drivers:
Since this happens on 2 different machines consider the possibility that the problem is with the dock.
Reactions: Gone9274
