Question "Driver Power State Failure" BSOD ?
Jun 4, 2024
Hello! I'm new here, but I don't know where else to look for help. My problem is that on average one day a week I get a BSOD with the message "Driver Power State Failure". I don't know what could be causing it.
Thank you for any possible indication of the cause of the failure
Below are the details from debugging:
0: kd> !analyze -v
* Bugcheck Analysis *
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffff9a85bace4360, Physical Device Object of the stack
Arg3: fffff80241f21178, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffff9a85c36cd010, The blocked IRP
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1515
Key : Analysis.Elapsed.mSec
Value: 7215
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 187
Key : Analysis.Init.Elapsed.mSec
Value: 2132
Key : Analysis.Memory.CommitPeak.Mb
Value: 102
Key : Bugcheck.Code.KiBugCheckData
Value: 0x9f
Key : Bugcheck.Code.LegacyAPI
Value: 0x9f
Key : Bugcheck.Code.TargetModel
Value: 0x9f
Key : Failure.Bucket
Value: 0x9F_3_AML!_SB.PCI0.GPP0.SWUS.SWDS.HDAU._STA_ACPI_IMAGE_pci.sys
Key : Failure.Hash
Value: {f81fa676-c506-d045-02e8-ba0ed753c0ad}
Key : Hypervisor.Enlightenments.ValueHex
Value: 1497cf94
Key : Hypervisor.Flags.AnyHypervisorPresent
Value: 1
Key : Hypervisor.Flags.ApicEnlightened
Value: 1
Key : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 0
Key : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key : Hypervisor.Flags.CpuManager
Value: 1
Key : Hypervisor.Flags.DeprecateAutoEoi
Value: 0
Key : Hypervisor.Flags.DynamicCpuDisabled
Value: 1
Key : Hypervisor.Flags.Epf
Value: 0
Key : Hypervisor.Flags.ExtendedProcessorMasks
Value: 1
Key : Hypervisor.Flags.HardwareMbecAvailable
Value: 1
Key : Hypervisor.Flags.MaxBankNumber
Value: 0
Key : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key : Hypervisor.Flags.NoNonArchCoreSharing
Value: 1
Key : Hypervisor.Flags.Phase0InitDone
Value: 1
Key : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key : Hypervisor.Flags.RootScheduler
Value: 0
Key : Hypervisor.Flags.SynicAvailable
Value: 1
Key : Hypervisor.Flags.UseQpcBias
Value: 0
Key : Hypervisor.Flags.Value
Value: 4853999
Key : Hypervisor.Flags.ValueHex
Value: 4a10ef
Key : Hypervisor.Flags.VpAssistPage
Value: 1
Key : Hypervisor.Flags.VsmAvailable
Value: 1
Key : Hypervisor.RootFlags.AccessStats
Value: 1
Key : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 1
Key : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key : Hypervisor.RootFlags.HostTimelineSync
Value: 1
Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key : Hypervisor.RootFlags.IsHyperV
Value: 1
Key : Hypervisor.RootFlags.LivedumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 1
Key : Hypervisor.RootFlags.MceEnlightened
Value: 1
Key : Hypervisor.RootFlags.Nested
Value: 0
Key : Hypervisor.RootFlags.StartLogicalProcessor
Value: 1
Key : Hypervisor.RootFlags.Value
Value: 1015
Key : Hypervisor.RootFlags.ValueHex
Value: 3f7
Key : WER.OS.Branch
Value: ni_release
Key : WER.OS.Version
Value: 10.0.22621.1
BUGCHECK_CODE: 9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffff9a85bace4360
BUGCHECK_P3: fffff80241f21178
BUGCHECK_P4: ffff9a85c36cd010
FILE_IN_CAB: 060424-9109-01.dmp
TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b
DRVPOWERSTATE_SUBCODE: 3
IMAGE_NAME: pci.sys
MODULE_NAME: pci
FAULTING_MODULE: fffff80247790000 pci
BLACKBOXACPI: 1 (!blackboxacpi)
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
fffff802`41f21128 fffff802`44f815a6 : 00000000`0000009f 00000000`00000003 ffff9a85`bace4360 fffff802`41f21178 : nt!KeBugCheckEx
fffff802`41f21130 fffff802`44f8147c : 00000000`00000004 fffff802`40161180 ffff9a85`c475f890 fffff802`41f212a9 : nt!PopIrpWatchdogBugcheck+0x122
fffff802`41f211b0 fffff802`44c6d68b : ffff9a85`00000005 00000000`00000001 fffff802`00000000 00000000`00000002 : nt!PopIrpWatchdog+0xc
fffff802`41f211e0 fffff802`44c60909 : 00000000`00000000 00000000`00000000 00000000`00000000 fffff802`40167c88 : nt!KiProcessExpiredTimerList+0x1eb
fffff802`41f21310 fffff802`44e1efee : 00000000`00000000 fffff802`40161180 fffff802`4574c700 ffff9a85`d7e94080 : nt!KiRetireDpcList+0xaf9
fffff802`41f215c0 00000000`00000000 : fffff802`41f22000 fffff802`41f1b000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x9e
IMAGE_VERSION: 10.0.22621.3652
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: 0x9F_3_AML!_SB.PCI0.GPP0.SWUS.SWDS.HDAU._STA_ACPI_IMAGE_pci.sys
OS_VERSION: 10.0.22621.1
BUILDLAB_STR: ni_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {f81fa676-c506-d045-02e8-ba0ed753c0ad}
Followup: MachineOwner
Mod Edit: Moved long log file to a spoiler to make thread easier to read.
Hi, welcome to the forums.
Look in the following folder for minidump files:
C:\Windows\minidump
You should have 1 or more .DMP files in there. Zip them up into a single file and upload them to a file sharing service like Google Drive or OneDrive and provide a public link here to download them. Make sure the link isn't password protected and anyone can download.
Then maybe someone will have a look at them to see if an answer can be found.
Reactions: ubuysa
