BugCheck 9F, {3, ffffe000026132b0, ffffd000203fe840, ffffe00002e13450}
Probably caused by : usbccgp.sys
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Built by: 9600.16452.amd64fre.winblue_gdr.131030-1505
System Uptime: 1 days 0:47:45.965
Machine ID Information [From Smbios 2.7, DMIVersion 39, Size=2556]
BiosMajorRelease = 2
BiosMinorRelease = 4
BiosVendor = American Megatrends Inc.
BiosVersion = 2.04.0250
BiosReleaseDate = 11/08/2013
SystemManufacturer = Microsoft Corporation
SystemProductName = Surface Pro 2
SystemFamily = Surface
SystemVersion = 1
SystemSKU = Surface_Pro_2
BaseBoardManufacturer = Microsoft Corporation
BaseBoardProduct = Surface Pro 2
BaseBoardVersion = 1
update this driver mwlu97w8x64.sys dated Fri Nov 08 15:35:29 2013
driver attempted to change its power state (go to low power mode) before completing its work, windows detected this error and generated the bugcheck.
Image path: \SystemRoot\system32\DRIVERS\mwlu97w8x64.sys
Make sure you are getting the windows updates installed. in particular you will be looking a updated Marvell Dualband 802.11n Adapter driver (mwlu97w8x64.sys)
as a work around you can go to power management and set this device to high performance, or tell the system not to put this device into sleep mode. Better to get a fixed driver
