Driver Power State Failure
Adnro
52
Often when i start my PC i get the BSOD: Driver Power State Failure
I looked in the Minidump it said: Probably caused by: atapi.sys
Some Info:
Running Fresh installed windows 10
My CD/ROM device doesn't recognize CD's somehow..
I got a SSD & HDD they are set on IDE
Hope you guys can help me fix this
okay ill look at the site and CD/ROM
Next dump gave me: (I did set it to Fulldump)
*** ERROR: Module load completed but symbols could not be loaded for node.dll
"KERNELBASE.dll" was not found in the image list.
Debugger will attempt to load "KERNELBASE.dll" at given base 00000000`00000000.
Please provide the full image name, including the extension (i.e. kernel32.dll)
for more reliable results.Base address and size overrides can be given as
.reload <image.ext>=<base>,<size>.
Unable to add module at 00000000`00000000
Probably caused by : atapi.sys
Power management starts with the bios functions. Update the bios. Then it is transfers to the hardware device drivers (update motherboard device drivers from motherboard vendor) some old devices might require a firmware update. This can include the CD player. For some machines/devices made during the windows 7 era and before will have bugs in the actual electronics you would have to disable the power management function for that device using control panel. Windows 7 had power management functions turned off by default. Lots.of systems shipped with broken designs. People did not find out until they install Windows 8 or above where the functions are on by default.
Okay i am working on it i found more stuff in the dump.
FAILURE_BUCKET_ID: 0x9F_3_IMAGE_atapi.sys
PRIMARY_PROBLEM_CLASS: 0x9F_3_IMAGE_atapi.sys
Still working on the tests and i disabled power management. (Did virus scan and Malwarebytes too..)
sfc /scannow result:
Windows Resource Protection dound corrupt files but was unable to fix some of them. Details are included in CBS.Log windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log. Note that logging is currently not supported in offline servicing scenarios.
