* Driver Problems * Please Help
G
Guest
Guest
Archived from groups: microsoft.public.games.discussion (More info?)
When I play Unreal Tournament my computer either shuts
off or it freezes.Sometimes I can play up to an hour and
than it's messed. You think it's my driver ?
What is the problem and how can I fix it ?
I already installed the latest update for my driver.
"Lajcsi" <anonymous@discussions.microsoft.com> wrote in message news:1916701c44c4d$779458a0$a001280a@phx.gbl...
Hardware issues can cause freezing, black screens and other
errors. Also, your drivers should always be kept up to date.
Try the following steps one at a time to try and resolve the issue.
I hope this helps. Please post back if you have any questions! 🙂
1. Update DirectX and your Chipset, Sound, &Video Drivers:
For all Video / DirectX / Game and Hardware Issues, I have a
Checklist of Solutions at: http://NibblesNbitsVideo.tk
2. Dust your fans, vents and components using a 1/4" paintbrush
and a hose vacuum. Use compressed air for hard to reach places.
Set a housefan to blow cold air into your case to expose an over-
heating issue.. If it works add more fans or replace defective ones.
Use this Motherboard Monitor Utility: http://mbm.livewiredev.com
3. A faulty power supply can cause STOP errors, random reboots,
and black screen lockups. One way to test for that is to check the
wattage sticker on your power supply and then calculate your need
http://www.jscustompcs.com/power_supply/ (Min. 350 for gaming)
4. Test your RAM using: http://oca.microsoft.com/en/windiag.asp
Cheers, Windows XP MVP Shell / User
Jimmy S. http://mvp.support.microsoft.com
Game FAQs: ;gms]http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
Visit my Zone.com / Gaming Helpsite: http://nibblesnbits.tk or Call / Contact
MS Support at: http://support.microsoft.com/default.aspx?scid=sz;en-us;top
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
