I posted this in the general graphics card forum but I figured id post here since this is more specific and the suggestions made did not solve my problem
I got this computer:
http://www.newegg.com/Product/Product.aspx?Item=N82E16883229266&Tpk=cyberpowerpc%201314
The GPU does not get detected at all it seems. It is securely in the slot on the motherboard. The fan spins when my computer is on. When I plug a DVI/ VGA cable in to my GPU ports, screen is black(didnt try HDMI as my monitor does not have one) when I plug the cables into my ports from my motherboard, a picture does appear on my monitor.
I tried to install the catalyst suite several times ( maybe im downloading the wrong thing) but it simply doesnt appear on my computer. Its not on my taskbar and the ATI technologies folder on my pc is completely empty.
I used driversweeper once to clear the drivers, but i have reinstalled my copy of Windows 7 after doing this because I thought that caused a problem( and I feel like it still did but idk)
I noticed this problem because I was playing sc2 and noticed my fps was really low compared to the fps benchmarks I've been reading(about 30 fps on low).
When I run dxdiag or look at device manager, it just says Intel HD graphics family manager as my video card.
If i left out important bits of information please let me know, I really would like to get this problem solved as it is quite annoying. Any and all help is appreciated thanks a lot.
EDIT:More information;
When I run the setup file to attempt to install the driver/catalyst control center it doesnt get past the part at detecting driver hardware, just freezes up and the only way to exit out is to close it through task manager. In safe mode it says it cant find the graphic drivers which i assume is normal because im in safe mode.
