Driver Problems with GTX 970
jack031700
41
I recently updated my 970's drivers. The most recent one ( 373.6 i think) makes my computer turn off, or the screen go completely black and crash when i play any game. I have tried uninstalling the current driver and installing new ones, even going back to last year. Yet every time either the monitor gets no signal or the monitor will go black, the game will crash to desktop, and it will say that the nvidia driver has crashed and recovered.
Specs:
Windows 7 64-bit
Asus Z97-A motherboard
I5-4690k
EVGA GTX 970 ACX 2.0
Corsair Vengeance Pro 16GB DDR3 (2x8GB)
WD GREEN 1TB HDD
700w COOLMAX CU Series
If your brother has the same drivers and has no problems then there is no driver issue, either your GPU or your PSU have a problem. Borrow a PSU off someone and see if it works.
So I was taking a look at EVGA monitoring stuff and it says that my 970 is running at 135mhz. Is that just because it is running at idle. Also, how would I check if the temp spikes if my pc crashes and the screen goes black when a game starts up.
I checked and the gpu did boost up to the regular speed once a game was loaded. Still same issue. The charts do show a spike in gpu temp but by only a few degrees
I did this and now sitting at idle, the card is running at the correct speed. However, not sure why that is necessary since the games still crash and now, won't my card run hotter even when I'm not doing anything?
It will add 1-2 degrees at most, put it back to the previous setting if you want to. I told you to do that because it fixed problems like yours sometimes. You are going to have to wait until a newer driver is released, which hopefully will fix that problem. If the problem still occurs, then your GPU is damaged in some way.
What I don't understand is that my brother's pc which is similar to mine is having no issues at all.
Yes I have ordered a new PSU. When it arrives I'll update this thread to let anyone else know if it is resolved.
