Question DRIVER_POWER_STATE_FAILURE (9F)
Aug 12, 2022
  • Bugcheck Analysis *
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffff900c0057a360, Physical Device Object of the stack
Arg3: ffff8c0758aef790, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffff900c005b9010, The blocked IRP
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1311
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 1359
Key : Analysis.Init.CPU.mSec
Value: 530
Key : Analysis.Init.Elapsed.mSec
Value: 9774
Key : Analysis.Memory.CommitPeak.Mb
Value: 102
Key : Bugcheck.Code.DumpHeader
Value: 0x9f
Key : Bugcheck.Code.KiBugCheckData
Value: 0x9f
Key : Bugcheck.Code.Register
Value: 0x9f
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Timestamp
Value: 2019-12-06T14:06:00Z
Key : WER.OS.Version
Value: 10.0.19041.1
FILE_IN_CAB: MEMORY.DMP
BUGCHECK_CODE: 9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffff900c0057a360
BUGCHECK_P3: ffff8c0758aef790
BUGCHECK_P4: ffff900c005b9010
DRVPOWERSTATE_SUBCODE: 3
IMAGE_NAME: pci.sys
MODULE_NAME: pci
FAULTING_MODULE: fffff80033070000 pci
BLACKBOXACPI: 1 (!blackboxacpi)
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME: System
STACK_TEXT:
ffff8c0758aef758 fffff8002ed60047 : 000000000000009f 0000000000000003 ffff900c0057a360 ffff8c0758aef790 : nt!KeBugCheckEx
ffff8c0758aef760 fffff8002ed5ff61 : ffff900c005ba1e8 0000000000000000 ffff900c220471f0 0000000000000000 : nt!PopIrpWatchdogBugcheck+0xdf
ffff8c0758aef7d0 fffff8002ea9da12 : ffff900c005ba220 ffffbe807a1ce180 ffffbe807a1ce180 0000000000000002 : nt!PopIrpWatchdog+0x31
ffff8c0758aef820 fffff8002ea6766d : 0000000000000000 0000000000000000 0000000000140001 000000000000385e : nt!KiProcessExpiredTimerList+0x172
ffff8c0758aef910 fffff8002ebfc45e : ffffffff00000000 ffffbe807a1ce180 0000000000000000 ffffbe807a1d9440 : nt!KiRetireDpcList+0x5dd
ffff8c0758aefba0 0000000000000000 : ffff8c0758af0000 ffff8c0758ae9000 0000000000000000 0000000000000000 : nt!KiIdleLoop+0x9e
IMAGE_VERSION: 10.0.19041.1741
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: 0x9F_3_ACPI_IMAGE_pci.sys
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {20ddeb92-07eb-ebdc-bd08-44da71ffbd68}
Followup: MachineOwner
I would update chipset drivers
what are specs of the PC?
Can you follow option one on the following link - here - and then do this step below: Small memory dumps - Have Windows Create a Small Memory Dump (Minidump) on BSOD - that creates a file in c windows/minidump after the next BSOD
  1. Open Windows File Explore
  2. Navigate to C:\Windows\Minidump
  3. Copy the mini-dump files out onto your Desktop
  4. Do not use Winzip, use the built in facility in Windows
  5. Select those files on your Desktop, right click them and choose 'Send to' - Compressed (zipped) folder
  6. Upload the zip file to the Cloud (OneDrive, DropBox . . . etc.)
  7. Then post a link here to the zip file, so we can take a look for you . . .
