Hi!
I've been facing issues with my PC recently, and I can't seem to pinpoint the cause. My PC has been shutting off the past few days regularly at around the timestamps 23:30pm till 1:30am whilst gaming.
The issue has pursued me across two Windows installations now as I tried to reinstall my Windows to see if my issues would disappear, as I have been having frequent stuttering problems in games, and thus I think this bluescreen is some sort of indication as of why my system is having these instability issues... and maybe the minidump can lead somebody to a cause? Cause I can't get my head around it.
My setup:
OS: Windows 11 Pro
GPU: MSI RTX 4080 Suprim X
CPU: Ryzen 7800X3D
RAM: G.Skill Trident Z5 Neo RGB F5-6000J3040G32GX2-TZ5NR
MOBO: MSI x670-P Pro
PSU: Corsair RMX Shift 1200W
I've tried the following:
• Clean install of Windows 10 & 11
• Updated all drivers, and tried rolling back some drivers to pin-point the problem
• Run the latest BIOS revision by MSI
• Disabled EXPO to see if the instability miraculously disappears but it hasn't.
• And this: https://www.tomshardware.com/how-to/fix-driver-power-state-failure-error
I want to add that my PC's temperatures are fine, 68c GPU and 65-74c whilst gaming, though under heavier load situations the CPU can run up to 84c under a Be Quiet AIO.
If anybody with the skill of debugging my minidump file here can potentially see a cause of what hardware in my case is causing this I would greatly appreciate it, the instability has been giving me headaches and not knowing what could be the cause makes it even more frustrating as this system isn't old at all, the GPU is only a recent addition! :/
Here's a link to my minidump as this is the first time my PC created one for a while, though those blackscreen freezes that suspiciously look a lot like a bluescreen crash have been happening more often with no dumps created if anymore get created I can upload them: https://drive.google.com/file/d/1wJcD6_goY9H6boGHHUxLXwZyzOPDOobI/view?usp=sharing
My setup:
OS: Windows 11 Pro
CPU: Ryzen 7800X3D
