Question DriverFrameworks-UserMode 10110 & 10111 + Kernel-Power 41 (61) ?
InsomniiaK
11
Hello,
I don't know if this has been posted before but here I go.
I had some problems lately with PC, I keep running into critical errors DriverFrameworks-Usermode (ID 10110 & 10111) and Kernel-Power (ID 41 (Task 63)).
I did a clean install of Windows (wiped everything) and then reinstall every drivers but the problem still occur (seems to happen mostly on intensive games, I never ran into that problem while playing League of Legends, but will often while playing games like Mordhau, Fallout 4...
So I did a memory Diagnosic and everything seems good.
I did a Memtest 86 and no problem there either.
I updated my BIOS to the latest version.
Nothing is overclocked.
I looked into the DriverFrameworks-UserMode and read on multiple forums that my headset could be the source...so I downloaded the lastest firmware of my headset and the problem still occur. I don't know if this is a sign that my headset is on his last heartbeat (I bought them back in 2016)..
I am quite confused because I never had this problem before. So, I don't if there's something faulty in my pc, if my PSU is faulty, if my mobo is faulty and I don't have anything to test every single part of the PC to see which part would be faulty.
I'll write down information about the errors that I get below so anyone can look further into this (I'm sorry everything is written in french - I can translate if needed).
Thanks to whoever can help me.
My specs :
● Motherboard → MSI Tomahawk x570 WIFI
● RAM → G.Skills Tridentz 3600MHz
● GPU → MSI Ventus RTX 2070 SUPER 8Gb
● CPU → Ryzen 5 3600 3,6 GHz
● Cooler → Corsair H60
● Hard driver & SSD → WD HDD 500GB, Intel SSD 250GB, Samsung SSD Evo 860, 1TB
● Mouse & Keyboard → Logitech G502 & G710+
● Headset → Hyper X Cloud 2 Black and Grey
Nom du journal :System
Source : Microsoft-Windows-DriverFrameworks-UserMode
Date : 2021-04-24 22:07:37
ID de l’événement :10110
Catégorie de la tâche :User-mode Driver problems.
Niveau : Critique
Mots clés :
Utilisateur : SYSTEM
Ordinateur : Maxime
Description :
Un problème s’est produit avec un ou plusieurs pilotes mode-utilisateur et le processus hôte a été arrêté. Par conséquent, l’accès aux périphériques peut être momentanément interrompu.
XML de l’événement :
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-DriverFrameworks-UserMode" Guid="{2e35aaeb-857f-4beb-a418-2e6c0e54d988}" />
<EventID>10110</EventID>
<Version>1</Version>
<Level>1</Level>
<Task>64</Task>
<Opcode>0</Opcode>
<Keywords>0x2000000000000000</Keywords>
<TimeCreated SystemTime="2021-04-25T02:07:37.3234464Z" />
<EventRecordID>6209</EventRecordID>
<Correlation />
<Execution ProcessID="940" ThreadID="668" />
<Channel>System</Channel>
<Computer>Maxime</Computer>
<Security UserID="S-1-5-18" />
</System>
<UserData>
<UMDFHostProblem xmlns="http://www.microsoft.com/DriverFrameworks/UserMode/Event">
<LifetimeId>{6b88656f-bb85-4eda-bc81-2730d595a8d5}</LifetimeId>
<Problem>3</Problem>
<DetectedBy>2</DetectedBy>
<ActiveOperation>0</ActiveOperation>
<ExitCode>259</ExitCode>
<Message>0</Message>
<Status>4294967295</Status>
</UMDFHostProblem>
</UserData>
</Event>
DriverFrameworks-UserMode 10111
ID de l’événement :10111
Niveau : Critique
Mots clés :
Ordinateur : Maxime
Description :
Le périphérique HID-compliant headset (emplacement (unknown)) est hors connexion en raison d’un blocage du pilote mode-utilisateur. Windows essaiera de redémarrer le périphérique à 5 reprises. Pour plus d’informations sur ce problème, contactez le fabricant du périphérique.
<System>
<EventID>10111</EventID>
<Level>1</Level>
<Task>64</Task>
Kernel-Power 41 (63)
Source : Microsoft-Windows-Kernel-Power
Date : 2021-04-24 22:06:28
ID de l’événement :41
Catégorie de la tâche (63)
Niveau : Critique
Mots clés : (70368744177664),(2)
Ordinateur : Maxime
Description :
Le système a redémarré sans s’arrêter correctement au préalable. Cette erreur peut survenir si le système ne répond plus, s’est bloqué ou n’est plus alimenté de façon inattendue.
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2021-04-25T02:06:28.2899277Z" />
<EventRecordID>6182</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">9</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2021-04-25T02:07:37.3245101Z" />
<EventRecordID>6210</EventRecordID>
<Correlation />
</System>
<UserData>
<UmdfDeviceOffline xmlns="http://www.microsoft.com/DriverFrameworks/UserMode/Event">
<FriendlyName>HID-compliant headset</FriendlyName>
<Location>(unknown)</Location>
<InstanceId>HID\VID_0951&amp;PID_16A4&amp;MI_03&amp;COL02\A&amp;392CDBD1&amp;0&amp;0001</InstanceId>
<RestartCount>5</RestartCount>
</UmdfDeviceOffline>
</UserData>
</Event>
