I need help downloading the correct drivers for my first computer build. I have a ASUS Maximus hero xi motherboard and a ASUS RTX 2070 oc GPU, if anyone can help with the drivers that I need it would be greatly appreciated.
Load up with more cores for more performance with the ROG Maximus XI Hero Wi-Fi, ready for 9th generation Intel® Core™ processors. The revamped ASUS 5-Way Optimization overclocks intelligently based on smart prediction and thermal telemetry while FanXpert 4 delivers dynamic system cooling. Aura...
www.asus.com
Chipset, Audio, LAN and Wireless are the ones your should need. Although chipset is the priority. Windows Update will likely handle the Audio/LAN, but best to install from the MB vendor.
www.asus.com
