[SOLVED] drivers problem
Jan 31, 2021
hello guys i have a pc it name vega book plus and it have windows 10 but he have very lag so i install windows 8 as dual boot with the windows 10
any way not this my problem my problem is i can't found my pc drivers (gpu,sound,wifi,bluetooth) i search in the most websites and i install a auto drivers
software without any think
so if any one can help me because my pc can't run windows 10 he is low-end pc
There is a good chance there is more than 1 of those model laptop, can you give me the Make/Model number of the device?
Then I can see what drivers exist for it.
I search in system information his module is VEGABOOK PLUS
That's it there's not anything else no product number
If you know how i can found it tell me
Screen size 14.1 '' 16 :9
  • Resolution 1366 * 768
  • CPU Intel Atom Cherry Trail Z8350 1.44 Ghz
  • 4GB DDR3L RAM with 64G ROM FLASH
  • OS Windows 10
  • GPU Intel Gen 8 HD Graphics
  • 0.3MP front camera
  • Hard drive slot
  • SD card up to 32GB
  • USB 2.0 ports * 2
  • RJ 45
  • Earphone out
  • Mini HDMI
  • Battery type 3.7V / 10000mAh Lithium polymer
  • Weight 1390g
Drivers... none on their own website. Always helpful, likely a lot of them should be in Win 10.
run this in Win 8 to see what drivers you have, we can always find alternatives in win 10
Can you download and run Driverview - http://www.nirsoft.net/utils/driverview.html
All it does is looks at drivers installed; it won't install any (this is intentional as 3rd part driver installers can mess up)
When you run it, go into view tab and set it to hide all Microsoft drivers, will make list shorter.
Now its up to you, you can look through the drivers and try to find new drivers,
or you can take a screenshot from (and including)Driver name to (and including)Creation date.
upload it to an image sharing website and show link here
All I would do is look at driver versions (or dates if you lucky to have any) to see what might have newer versions.
Hy my friend i have do what you say but there's not any driver appear in the program that you give me
This image with Microsoft drivers
https://imageupload.io/LH6Rm48wcu.i
And this without Microsoft drivers
https://imageupload.io/ko5BpBkrST.i
I don't know what i do i really need win 8
I can't use win 10 is really lagging
I even try to backup drivers from win 10 and i restore him in win 8 but doesn't work
