Drobo 5N 5-Bay NAS Review
  • Thread starter Thread starter Guest
  • Start date Start date
Pretty weak CPU, no way it's doing any PLEX Server duties. That's kind of a must have features nowadays. Although this NAS is around 3 years old, odd that toms is just now reviewing it.
Kinda odd to see this up and running in a review when its been out for so long. It's 3+ yr old tech in this thing so its not surprising that its not wowing anyone with its specs. I love mine tho.
Difficult to recall how long the 5N has graced my storage space. As a recovering DP manager from the era of big iron and big budgets I had zero interest in becoming a networking wizard. The 5N has done everything I needed from it - and Drobo has routinely provided both hardware and software updates that, as far as I can tell, keep the device relevant. What I purchased as a 15Tb device is now capable of 30Tb, and possibly 40Tb.
Do I appreciate the 'aged' technology - you better believe I do. The last major shop I ran the available storage on this device would be the biggest budget bomb ever - .
I've had mine for three years and I love it. It has worked flawlessly during that time, including having two hard drive failures ( cheap drives ). I'm now running five 4TB WD red NAS drives. I have this drive attached to a small PC running Plex = awesome!
I've been using mine since June of 2013 and have found it an excellent backup destination. I started with two 3tB WD Red drives then filled up with three more and when the space started to get tight I stuffed in two 6tB. The drive upgrade process, while slow with huge drives, has always run perfectly. I used to be a UNIX sysadmin before retiring and really didn't want to get into any complexities at home -- the Drobo filled the bill and saves headaches and worries.
