Dropped and intermittent audio..
TheDoc
8
Archived from groups: alt.cellular.sprintpcs (More info?)
I have an N400 that has always had a "problem"
with the audio.. on some calls ( both incoming and outgoing )
the connection is made, the reply is heard but the recipient receives
no audio.. it's as if the connection is "one way"
... is this a phone problem or a sprint problem..?
any comments..
TIA
Could be either, should have returned the phone when you first got it. The N400
is a known problem phone that they eventually got a FIRMWARE upgrade for,
which could help.
A local full service Sprint owned SprintPCS store should be able to help you.
> which could help.
Seconded.
N400 handsets have issues, usually related to freezes that require
battery removal.
Check the FAQ at Sprintusers.com for your phone's latest firmware
revision - my experience was that the reliability, while not perfect,
was about twice as good after the revision was applied by my local
Sprint store.
-mike
"Mike" <spamtrap@zbuffer.com> wrote in message
news:ANMDc.30952$Y3.21945@newsread2.news.atl.earthlink.net...
The N400
for,
> > which could help.
you.
> Seconded.
> battery removal.
> Sprint store.
> -mike
Thanks.. I'm off the store..
