I did a search, but did not find an answer.
My question is, can I hook the cpu fan directly to the PSU, and let it run 100% all the time? Then, keep the rear fan on the sys_fan and use easy tunes to adjust rpms as needed? The risk here is that the MB will not detect a cpu fan, and cause a boot failure, or at least warnings.
Background - I used the following configuration to start;
CPU_FAN to intel cpu fan
SYS_FAN to rear case fan
PWR_FAN to front case fan
I didn't like this originally, because the cpu fan was just barely turning, sometimes starting and stopping immediately, due to low MB temps. I shut off smart fan control in bios, and now it runs all the time, but so to do other case fans, with which the rear seems loud.
I would like to control the rear case fan (sys_fan) separately, but do not see separate settings for it and the cpu fan in easytune5.
I think (correct me if I am wrong) that easy tune 5 adjusts all fan speeds from one setting. If you change the 20C mark from 20% to 30%, then all fans run 10% faster. So, I need to separate the rear fan from the cpu fan if I want the cpu fan always on, and the rear on only as needed.
mitt
mitt
