DSL (Damn Small Linux) Live USB Issues
army_ant7
629
I need help! As you may know, DSL can boot from a live USB. I've tried all 4 guides at DSL's wiki, http://www.damnsmalllinux.org/wiki/index.php/Install_to_USB_From_within_Windows . Method 1 and 3 worked, but the problem is when the booting started, it hung at "Checking for for USB..." as in the blinking cursor stopped blinking. Even when I boot from a live CD that is still the case; just so I could boot, I have to remove my pendrive, thus I can't use the pendrive. What should I do to boot from a live USB?
These are my specs if needed:
Mo-Bo: AsRock N68PV-GS
Pendrive: Transcend V30 2GB
CPU: AMD Athlon 64-bit X2 2.4GHz +4800
No, I'm sure it's not that. It's like this. I tried booting from a live USB first, but then at the phase of the booting that says, "Checking for for USB...," it gets stuck. So after that I tried to use a live CD, but during the boot-up process, the same thing happens. So I tried taking the pendrive out. The boot worked, but I obviously couldn't use my pendrive. How can I resolve this.
Hmmm... Are you 100% sure? The only other thing I can think of is that the USB pen does not support booting, some just don't work. Is the pen recognised if you plug it in once booted? I know it won't let you use it for config storage that way but it might give us a clue.
No. With DSL, you can't or I don't know how you can read a USB stick if you don't boot with it. I'm still learning the ropes you see... Without anything else for booting, other than my HDD which has Windows which I don't select for booting. It reads the pendrive ok. But once the booting happens. The phase where it says, "Checking for for USB...," it hangs like I said.
Yup, I did turn on legacy support. I'll try disabling it and come back to you guys. :)
It's weird. When I disabled "USB Legacy Support," the BIOS didn't read my pendrive as bootable. I know this pendrive is not legacy, or is it? There were 3 other options, namely: For BIOS Use Only(or something like that), Auto, and Enable. I also tried "For BIOS Use Only." It booted, but the same thing as before happened still in the booting phase of "Checking for for USB..." In the USB configuration options there were also "USB 2.0 Support" and USB Controller(I think).
It doesn't seem to be detected. Dang! Well, when you put in a pendrive, it said that there should be an option to mount it. Mine doesn't get that option for some reason. I can't access the contents either from mnt/sda. Is there a "cheat code" or driver I need to use. My ethernet card doesn't get detected. I tried installing from a CD, but it won't allow me because, after all I am using a live CD.
Hmmm.. what file system are you using on the pen drive? Did you format it under windows and can you see it when you boot windows if that is an option. Also do you have another pendirve that you can test with, and have you tried plugging it into any of the other USB ports?
Your kit is reasonable so this should all work. Any other liveCD's to hand that you can try? The Ubuntu one does have an automounter so anything you plug in after booting should appear as an icon on the desktop.
FAT32.
Yes and what do you mean can you see it when you boot Windows? When I'm using Windows? Yeah, it can be seen.
No and I haven't tried that yet.
Do you mean other than DSL?
Yes, I do mean other than DSL. The format is fine, FAT32 is the lowest common denominator in terms of formats so that should be OK. The fact that it works under windows shows the drive is working. I have to be honest I'm running out of ideas. The only thing I can think of is that your chipset is no supported under DSL. Good as DSL is it's not the most up to date of distributions.
I suggest you try a differed linux distribution, Ubuntu & Fedora are both well known for supporting more recent HW as they have a very active development community. The Ubuntu liveCD will allow you to use it just as a liveCD or to install it. You might well find it also supports your network card. It could be a boot option (cheat code) but I'm not familiar with all of them. Maybe one of the other folks down here might have some other suggestions.
Actually I'll add another suggestion in terms of other distributions to try, Slax is more like DSL than either Fedora or Ubuntu. Other than that you could try the 'waitusb' cheat code but I really doubt that will help you out much. Try that with the pen drive plugged in, it's got to be worth a shot.
As audiovoodoo said, your hardware is modern enough to have some issues with DSL.
Definitely give Ubuntu and Fedora a try, they are updated every 6 months and usually support more recent hardware quite well.
If Ubuntu doesn't work try Fedora and vice versa.
Fedora usually works on hardware that Ubuntu doesn't work on and sometimes the other way around.
http://www.ubuntu.com/getubuntu/download make sure you get the 64bit amd64 version!
http://www.fedoraproject.org/en/get-fedora-all make sure you get the x86_64 / amd64 64bit version!
Good luck :)
It could still be your pendrive or your usb controller on your motherboard but definitely try Ubuntu and Fedora and see if it happens again.
If the same problem happens on Ubuntu, Fedora and DSL then the problem is probably caused by your your usb controller or pendrive.
Have you tried any other pendrives / usb flash drives?
DSL uses the 2.4 kernel and only releases a new version every few years.
Ubuntu and Fedora use some of the latest 2.6 kernels and release a new version every 6 months so they have much better hardware support and offer the latest versions of most applications.
Again make sure you get the x86_64 / amd64 64bit version, it runs a lot faster and has nice features which the 32bit version doesn't.
Good luck :)
It's an onboard NVIDIA GeForce 7050 PV / NVIDIA nForce 630a.
Thanks for your help. I'm really appreciating this. You don't have to do this of course, but it's up to you. :)
That should work fine, try Fedora11 x86_64 and then Ubuntu desktop amd64 :)
rpmfusion has the nvidia drivers for Fedora and ubuntu should volunteer to install the nvidia driver for you.
Good luck :)
