DSL modem and belkin wireless router on same network?
jkcal436
I have a DSL model from AT&T that gives me 4 ports and I have a Belkin Wireless router that gives me another 4 ports. BUT, the computers on the AT&T modem cannot see the computers on the Belkin router. Should I set the address in the Belkin router to the one the AT&T modem has?
sturm
Splendid
Turn off dhcp on the belkin. Let the AT&T modem hand out IP addresses.
Plug the cable from the modem into one of the normal switch ports on the belkin. This will help prevent two different networks which is probably why the comps can't see each other.
jkcal436
Alright, I am getting close. I turned DHCP off. The default gateway on the AT&T modem is 192.168.1.254. So I changed the Belkin to 192.168.1.1 and totally screwed it up. I now have it back to 192.168.2.1 Where do I go from here?
Emerald
Check the AT&T modem and make sure the DHCP does not use the 192.168.1.1
I would set the DHCP to only use a range of 50 IPs like Starting 192.168.1.51 and Ending 192.168.1.100
change the Belkin back to 192.168.1.1 and turn off the DHCP. Setup you wireless security.
Now connect one of the four LAN ports (NOT the WAN/Internet port) of the Belkin to the AT&T modem
Similar threads
